跳转到主内容
修复你的物品
维修的权力
配件 & 工具
A piece of plastic broke off of the ethernet adapter
Just today a piece of plastic fell off of the ethernet port on the side of my mom’s laptop. It snapped right back in, but it is very noticable and I’m wondering if something worse will follow this issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Can I look at a picture of it?
完成的
Not sure how to send a picture, but it's this little rectangle piece. I can't even make my finger's quite the right size, but it's extremley small.
完成的
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
1个回答
最有帮助的答案
That is a lock tab which helps hold the ethernet cable in. It’s called an RJ45
Usually you have to press it down when removing the plug. It’s not going to cause any harm but your cable may fall out. Just replace the cable.
You can get them in almost any electronics supplier.
Here’s one for $4.66 https://cables4sure.com/cat5e/cat5e-plen...
这个答案有帮助吗?
得分 1
评论:
Is that on the cable or port? I didn't mean to say adapter, this is on the latpop's port.
完成的
We will need to see exactly what you are talking about. Here's how to add images:
在已经存在的问题里加入图片
完成的
添加一条评论
添加你的答案
mrmanman 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 24
