跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
702 个问题 查看全部
Why wont my screen work after LCD & digitizter replacement?
I recently replaced the LCD and digitizer on my Nintendo Switch and the screen wont turn on (black screen). What damage could of occurred if the battery was not disconnected prior to the replacement? Is there a way to test the LCD screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you ever figure this out? Having a similar issue?
完成的
添加一条评论
1个答案
It may be possible that you shorted out the screen while connecting. Try restarting the device and charging it. If it still does not turn on make sure the device is turned off and see if there is any loose connections somewhere or the connector is not seated properly. Hope your problem gets solved and you dont need to replace again
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adambaker88 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 742
