跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
Hewlett-Packard于1993年开始制造个人笔记本电脑。
1911 个问题 查看全部
HP Eleitebook 6930p no boot after repair
I have a old HP Eleitebook 6930p which was working perfectly until I cracked it open to replace the DVD drive with one of those holders to add a second HDD. I took it apart, replaced the part, hobbled everything into a pile and booted it successfully off the battery, then reassembled it properly but now it will not boot. When on battery and I press the power button the charging LED flashes blue and white then wireless activity light and the HDD activity light turn solid yellow and after that the 3 lights shut off. If on a power chord with no battery the same thing occurs but I can hear the fan spin and if its on a power chord with the battery plugged in the same thing occurs. I’ve tried the press and hold the power button for 30 seconds without the battery then plug it in and try to turn it on with no luck. Considering I’m a big handed impatient clumsy person I’m 100% expecting that I stabbed something impotent on the mobo with my screwdriver or happened to static shock something important but I figured checking with the ifixit community first was a good idea. I can get a use one if these in fully functional but poor condition for 20-40$ so I’m not to worried if I need to replace the mobo.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
With the battery removed and power supply disconnected, SLOWLY take it apart again and SLOWLY reassemble making sure all the ribbon cables are correctly inserted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh Miller 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 11
