跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Comprehensive set of repair guides for playthings for children of all ages.
780 个问题 查看全部
Replacement connector wire for singing chipmunks
Where can I get a new connector wire for two singing penguins? They are supposed to be connected to each other with a thin wire and then respond to each other when the button is pushed. I no longer have the wire. Attached are pictures of the label, ports, and front of the penguins. Thanks for your help.
Update (09/15/2019)
I can’t believe you know what I’m talking about. I am sending two of the best close up pics I could take. If these aren’t good enough, let me know and I will send more. Thanks for all your help.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 1
评论:
lls761 looks like not to many people are familiar with what you are looking for. Post some good pictures of the toy as well as the wire and, if there are any labels, with your question. It may help us to identify the issue and help you resolving it. 在已经存在的问题里加入图片
完成的
I am not sure if my responses have posted. I will try again. Attached please see pics of the ports, label and the front of the penguins. Thanks for any help you can give me.
[image|1846039][image|1846037][image|1846036]
完成的
Trying to repost pics.
[image|1847381][image|1847379][image|1847380]
完成的
Dueling Banjo Penguins Christmas. Lets see what we can find. any chance you can get a close up of the connector. Looks a bit like a 3.5 mm connector on both ends
完成的
I found the name of the product:
Animated Dueling Penguins, sold at Walgreens originally.
Music by Mike Aehle
https://www.youtube.com/watch?v=qe5n2WPw...
I still can’t find details on the cable, but it is likely a very simple cable that can be easily replicated or replaced. A lot of times, these things use 3.5mm or 2.5mm male to male mono cables to communicate. (These are the ones where there are 2 metallic section on the plug separated by a plastic ring. Stereo version will have 3 metallic sections with 2 plastic rings.
They also made other dueling banjo toys including snowmen, bears, etc. Maybe we can run-down the info from those variants as well.
完成的
显示更多的1条评论
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
1个回答
已选择的解决方案
@lls761 okay this is still a bit hard to see. Try and check if a small headphone jack can be inserted into one of the connectors and if it feels like it fits. It most likely is a 3.5mm m/m Audio Cable Something like this
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lls761 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 1
总计 59
