跳转到主内容
Repair guides and support for a wide range of small engines.
103 个问题 查看全部
Atv engine sounds like the idle is going up and down
On my atv which is a taotao Chinese 110cc kids atv the engine sounds like it’s idle is going up and down and it sometimes stalls when I give it gas or when i get it to cold start I have to turn on the choke then turn it off immediately as soon as it turns over. I had a different carburetor on there and it wasn’t doing this but that carburetor had a leak somewhere and was not letting engine run because it kept flooding the engine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Most likely can be a gasket near throttle or carb that needs replacing or bolts tightened to spec a bad gasket or vacuum hose or tube that is damaged at ends ripped pinched frayed or disconnected which will cause the symptom you described called THROTTLE OR IDLE SURGING try listening for hiss or whistle of air or vacuum leaking around where gas line meets carb.
这个答案有帮助吗?
得分 1
添加一条评论
Well first off if you have a problem right off of idle then you have a pilot jet issue.if it stumbles after a quick blip of the throttle then it's too lean.if you can adjust the air screw or the fuel screw on the side of the carb then do so until absolutely no hesitation after a quick throttle blip.if you can't adjust enough to fix the issue and depending on which screw you have you need to either install a bigger pilot jet or a smaller one.as far as a fuel leak verify the leak location.if it's coming out from the over flow tube the the float is set too high or the float needle and seat need to be checked out for a sticking open problem.if the float needle is the cause you will need to replace the needle and seat
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Triple Forza06 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 30
过去 30 天: 100
总计 5,290
