跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
121 个问题 查看全部
问题已关闭
no backlight on screen
I am having a problem with the brightness on my display .There is a image on the screen when the laptop i completely open .When I close the laptop to about 15 degrees or so before completely closing the screen brightness comes back on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Replace the inverter cable that seems to be be broken in the PB hinge. You still have a backlight connection when moving the lid but sooner or later you'll lose it when the cable will be completely separated. Do the repair as soon as you can cause there's a risk to damage the logic board if the cable short in the hinge. Don't move to much the lid when the PB is powered until the cable is replaced.
这个答案有帮助吗?
得分 2
添加一条评论
Check the cable. the cable was pinched.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,805
