跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
466 个问题 查看全部
Line on screen after LCD replacement
Since replacing my iPhone XR screen i’ve had this black (sometimes white) line appear when pressure is applied to the bottom right corner of the screen. If i separate the screen and phone with a layer of electrical tape the issue doesn’t occur. I assume this is some sort of electrical interference but cant seem to isolate what is causing it.
Any suggestions would be much appreciated :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
4个答案
最有帮助的答案
There are two possibilities here; either the replacement screen is defective or you may have incorrectly assembled the screen.
If you still have access to the original screen, you could try installing that one to see if the problem persists. If it does, there may be some damage to the logic board (probably the connectors). If it doesn’t, the go through this guide to double-check your work as some screens, especially lower cost aftermarket screens can be thicker and cause issues with pressure points.
Also, was the replacement screen a “complete” screen with small parts or did you have to transfer everything over? Pre-populated parts can be problematic but transferring parts can lead to alignment issues. Do some more testing and verification and come back with more details.
Final question, is the picture of the phone innards your device or a photo from the web? It has an awful lot of scratches, markings and the battery looks like it has seen better days. Let us know if the phone has been previously repaired.
这个答案有帮助吗?
得分 4
添加一条评论
I think you need to try reconnecting the display to the phone. True, for this you will need answers and little experience in repairing such devices. Although it seems to me that it’s best for you to turn to the master who replaced the screen for you.
这个答案有帮助吗?
得分 0
添加一条评论
Most likely it’s nothing than a damaged screen, thos line are normal for damaged screen, the reconection with motherboard will chang nothing, or there is possibility of cracked pin in phone connector, but this thing is the best check on another lcd.
这个答案有帮助吗?
得分 0
添加一条评论
Hi Elisha
i Repair iPhones for a living and that is a screen faulty and Make sure the battery is disconnected because that can damage the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Elisha Mawson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 1,451
