跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
326 个问题 查看全部
MacBook Pro 2017 White Screen & Screen Flickering, any solution?
Hi,
I opened the lid/display of my Mac & I saw white screen around the edges. Did everything according to Apple. SMC, VRAM….
I don’t have Apple warranty anymore.
The problem appear when every time I close down my Mac display & when I open the lid I see the whiteness & flickering….Whiteness & flickering goes away after being opened for a couple of hours…...So, I have figured out that if I keep my Mac’s lid open it is perfect, there’s no problem whatsoever with the Mac…No white nowhere nor the flickering……So, for 2 days I am keeping my Mac Display open & I will try to keep it open until I find a solution.
I turn off the Mac, I put it to sleep..there’s no problem with the Mac at all.
So, could be the problem & any solution?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your displays T-CON board which is located just above the heatsink within the main case is over heating. I suspect your fans are not running properly and/or you have a lot of dust preventing the system to properly cool.
Do make sure you have not blocked to external vents (using your system on your bed as an example). I would recommend getting a good thermal monitoring app like TG Pro
If cleaning the dust out and the system overtime is not running too hot. You will likely need to replace the display assembly to fully fix this.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alberrt Bur 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 491
