跳转到主内容
Refrigerator repeatedly stops cooling (freezer/lights work)
Our garage refrigerator (Kenmore with the freezer on the bottom) started not cooling in late July. The lights kept working & the freezer kept working, but the top part (the refrigerator section) stopped cooling and the temp adjustment buttons stopped working for the refrigerator section too. We unplugged it for 24 hours & when we plugged it back in, it started working just fine again... until about 2 weeks later when it happened again. This time while it was unplugged, we cleaned & vacuumed under it and behind it really well and when we plugged it back in we made sure it was pulled out a ways from the wall. Again, it fixed the issue and worked fine for maybe another week or so, but then it happened again! So repeated the process and it did the same thing again yesterday!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Could be the automatic defroster element/circuit has stopped working and ice build up has stopped the fan that sends cool air into your upper section. When you unplugged it, the ice melted, and once plugged back in, the fridge worked again due to the fan being back in operation, until the ice built up enough to once again stop the fan from rotating. This condition will keep occurring until the problem with the defrosting circuitry has been repaired.
Edit: Probably a good idea to post the model number so that the more experienced participants here have an easier time with helping you resolve your problem. :-)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ariel Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 28
