跳转到主内容
修复你的物品
维修的权力
配件 & 工具
2.26 or 2.4 GHz / White plastic unibody enclosure
717 个问题 查看全部
Display not working after logic board replacment
I recently replaced the logic board of my Macbook Unibody A1342, but now when I go to turn it on the display dosen’t work. The first time I turned it on after replacing the logic board, it worked fine. The second time I turned it on, it showed some black bars. I simply turned it off, unplugged the batttery, and pushed the display connector in further. It worked after that, but after turning it off and back on, the display shows nothing. The fan is still running and if you leave it plugged in just sitting around for a while the fan does emit heat from the CPU.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
已选择的解决方案
An adapter to an external monitor or Tv would be needed to get confirmation the graphics are in working order. You can also try to shine a bright light to the screen to have an indication of a lack of image or backlight. However if you can do both trials you’ll have better hints.
这个答案有帮助吗?
得分 3
评论:
Ok. I'm going to try both of those. Would a phone flashlight be bright enough, or do I need something seriously bright?
完成的
The logic board I bought said "pulled from a working machine," so it's probably not the graphics.
完成的
Can't see anything with a flashlight, so it's probably a display problem (unless the sellers lied about the logic board)
完成的
@conzo A phone flashlight will certainly do, just do it in a shadowed or darker environment.
完成的
@arbaman Ok! I'll try again when it's darker.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
mrmanman 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 30
