跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1645 个问题 查看全部
Why is moisture forming between my ice marker and door gasket?
Recently we have noticed a lot of moisture forming around the gasket between the door and ice maker. We are constantly making sure the door is closed throughout the day and it still happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Damaged or worn seals around the door that are leaking cold air, or because the temperature is set to be too cold
这个答案有帮助吗?
得分 1
添加一条评论
I overheard a guy talking about something you add on refrigerator to prevent that from happening , ask something like a heat module to prevent condensation
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin Tomyk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 36
