跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
What are the consequences of jumping a broken FL11 next to the battery
While unplugging the battery I accidentally removed the FL11 right next to the battery connector (on this image https://d3nevzfk7ii3be.cloudfront.net/ig... it is the one that is two to the left of the one circled). The phone would then show 1% battery and reboot every couple of minutes.
I couldn’t find any micro soldering places nearby so I decided to try and short FL11 it with a bit of conductive paint. The phone now seems to behave perfectly well. What are the consequences of jumping FL11, that might not be apparent?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
There is no FL11 in an iPhone SE, I believe you are referring to FL2400. Here is what the SE looks like.
The picture you provided is an iPhone 5S and you are not highlighting the proper part. Here is the 5S battery connector layout and FL11 highlighted in yellow.
Regardless, they both serve the same purpose. This component is a chip ferrite bead and it is used to filter high frequency power supply noise. When probing a ferrite bead in DC mode, it will read ~0 Ohms (actually tens or hundreds of milliOhms). However, as high frequency noise gets more intense, it will become resistive and dissipate the noise energy in the form of heat. The specs for a ferrite bead are resistance (at a certain frequency) and current capacity.
However, popular wisdom has it that the ferrite bead is more like a “fuse”, blowing when there is excess current. In that sense, you can short the two pads rather than replace it and the phone will work fine afterwards. This works in a pinch but for a professional repair, it should be replaced. In your case, you have put conductive paint and it seems to work but I don’t see this as a long term solution and there is no guarantee that it will work properly depending on the actual resistance of the bridge you created nor it’s current carrying capacity. Too much capacity can allow more current than should safely move downstream to other subsystems.
这个答案有帮助吗?
得分 6
2条评论:
Thanks! You're right I couldn't find much information on the SE and I assumed to be the same as the 5S. I'm just hoping it will last a few weeks as I was already in the process of searching for a new phone.
完成的
@refectio Great answer 100%
完成的
添加一条评论
添加你的答案
Filipe Maia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 478
