跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
427 个问题 查看全部
98 accord battery dying & overheating
Last weekend my Honda wouldn’t start. Hooked it up to jumper cables, let charge for a minute & it started. Next morning leaving work it began running hot, stopped put water in it & drove it home. On that ride it fluctuated up & down. Ran fine for 2 days then I went in Walmart for a minute came back out it was dead. It jumped right off but then started running hot again & fluctuating up & down. Went to the store the next day didn’t run hot but when I came out it was dead again but I shook the cables & it started. I was just wondering what you guys may thinks going on with it. -always ran fine til now. -I think I may have some frays in my serpentine belt cause I can see them while it’s spinning.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If it wouldn't start but then did start after moving the battery cables around then your battery wasn't dead. You may however, have dirty battery terminals, loose battery connectors, loose wires, other dirty or loose connectors (ie starter motor) which will cause intermittent problems. Disconnect the battery clamps, clean and re-tighten and disconnect,clean, and re-tighten any other relevant connections. Use a multimeter to check battery cable wires for continuity while wiggling the wires while disconnected from the battery. Re: overheating (not sure if you are referring to the battery or coolant system but will assume cooling system) Check your radiator water levels, hoses and their connections and under the vehicle for possible coolant leaks. Or just say bugger it and take it to your local garage to test with their computer and tell you what's wrong! lol
BTW, all things "run fine" right up to the minute when they don't work fine. :-)
这个答案有帮助吗?
得分 2
2条评论:
I think my water pump may be out bc all my water is pouring out of my car right where the pulleys are as soon as I put it in.
完成的
When you put in more water, was the car running? As far as I know, the water pump should not leak unless the car is running. If the car is not running, it might be a hose going to/from the engine. Also, make sure you use the right 50/50 mix of water and antifreeze that is specified in your owners manual.
完成的
添加一条评论
As Prop Man said for the battery.
Your water pump is worn also. Get it replaced because it that goes bang, I have no idea what damage that will do to the pulleys, belts or anything else.
这个答案有帮助吗?
得分 0
1条评论:
Antifreeze does not attack or damage rubber, but it is dangerous if it gets on the belt because it gets it wet and it might slip off. If it does it will wreak havoc on your engine. If you aren't experienced with engine repairs you will need to get it towed to a shop because it messes up the valvetrain and lots of other stuff.
完成的
添加一条评论
添加你的答案
Carmen Kemp 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 249
