跳转到主内容
修复你的物品
维修的权力
配件 & 工具
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
95 个问题 查看全部
Why does my iPad Pro restart seemingly randomly, even when plugged in?
I have a 12.9-inch iPad Pro (1st gen I believe) that I like to use for sheet music. However, it suffers from the problem where it restarts, seemingly out of nowhere. After it reboots, the battery displays at 1% before going back to whatever level it was at before. This problem persists even when the iPad is plugged in or is at 100%. Besides this restarting issue, everything else seems to work fine.
The problem seems to happen less if I go for a long period of time (e.g. a week or more) without using the iPad, but as I use the iPad, the problem happens more and more often, eventually to the point where it does this around once a minute, making the iPad basically unusable.
I can try to record on video such a restart happening, if that would be of any use.
I visited an Apple store with this issue and there were no conclusive results.
Thank you.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 1
评论:
"no conclusive results" but I suspect a recommendation as a starting point, yes? Sometimes biting the bullet and just going for it is the only answer. :-)
完成的
@propman Apple recommended just to buy a new one, but I’m hesitant to do so because the iPad is functional aside from the restarting, and the price is large. I’d (obviously) rather fix my current one if possible.
完成的
@sparklepony Seems funny that they wouldn't have recommended to install a new battery especially considering the age of the unit. Personally if I was wanting to fix the unit, that would be the first thing to be replaced, but then again I do all my own work on my own stuff. Others mileage might vary :-)
完成的
a video would be great thanks
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
@sparklepony this alone “After it reboots, the battery displays at 1% before going back to ….” would lead me to replacing the battery. Remember that Apple does not want you to repair yours, they want you to buy a new one. Start off with a new battery then re-evaluate. Check this teardown iPad Pro 12.9" Teardown or this video to see if you think you can get it done or you may consider getting it changed by some professional.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Comrade SparklePony 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 34
过去的30天: 148
总计 1,020
