Asus BIOS laptop problem
So, the display of my ASUS laptop crapped so I took it off and I took off the “circle” that connected the display to the MOBO tho Windows 10 says that there’s a display connected(the display that I took off)and the problem is that I can’t even access the BIOS because the old display is probably still recognised as the primary display and I tried connecting 2 different monitors with VGA and HDMI. Thanks in advance
ASUS F555L
Hi @noscancel ,
What is the make and model number of the laptop?
Also what is the make and model number of the earphones in your other question?
Please edit the other question to show the model number.
To edit click on options > edit in the question
由 jayeff 完成的
Hi @noscancel ,
Did you try booting into windows 10 (without a display I know - can you hear the Win 10 startup music?) but with an external monitor connected either to the vga or HDMI port and then toggle through the display options by pressing Fn+F8 (together) to check if you can see a display in the external monitor?
Probably won't work in BIOS though if you changed the primary display it looks at the graphics adapter not the display that's connected to the adapter and you've probably only got one adapter onboard. Windows tells the BIOS to switch the video output to the different connections, internal, external or both. At least that's how I think it works ;-)
由 jayeff 完成的
@jayeff In Windows 10 I can use the monitor the problem comes when I try to go to the BIOS and if it like you're saying that's too bad :\ because I wanted to install a light linux distro so I can use it for server hostin :|
由 NOScancel 完成的
