跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2687 个问题 查看全部
My iPhone 6s stays stuck on progress bar/white apple screen
Hello,
After years of not updating to the new IOS, I’ve finally decided to do so and then my iPhone 6s stays stuck with the progress bar 1cm away from its completion. I’ve kept it on all night and same result, as if it freezes every time.
I didn’t get a chance to backup all of my photos upon this occurring. I want to seek professional help and would rather pay, since I’m afraid I may mess things up.
What should I do? Is this issue repairable without my photos being lost?
Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello. Try to hard reset the phone by holding home and power buttons together. This may cancel the update or restart installation. If that works, backup all your photos and other data. Then you can try updating it though iTunes on a computer, or connect the phone to iTunes and restore it and you will be able to restore the backed up files and have the phone updated too. Hopefully this works.
这个答案有帮助吗?
得分 1
2条评论:
Yes, I did exactly what you said, by force restarting it. It only takes me back to square one, it does the same thing. I also took it to my friend’s repair shop and he turned it on and connected it to iTunes, it never loaded and stayed stuck on the progress bar.
Thanks
完成的
You could restore it with iTunes by putting it in recovery/dfu mode but then your data is gone
完成的
添加一条评论
最有帮助的答案
Don't do a restore just yet. Most iOS updates done through phone settings and get stuck are fixable by forcing an update through iTunes with the phone in recovery mode without losing data. Try getting your friend to force an update (retain user data) on there and not a restore that should fix this problem.
If the update fails with error -27 the phone must be restored and data can't be recovered without the use of a prior backup.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jay Ray 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 852
