跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
872 个问题 查看全部
Replace my iPhone 8 Wifi Antenna?
My iPhone 8 will no longer connect to any WiFi networks…in fact the option to connect to WiFi is greyed out. I’ve tried everything to get it to work. Sound like a hardware issue? Will replacing the antenna solve my problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If the antenna were broken you would still be able to get WiFi signal, it would just be very faint. If the WiFi option is grayed out entirely that indicates an issue with the WiFi chip on your logic board. You’ll need to find a microsoldering professional who can fix that chip for you, it isn’t a DIY project.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
RAF 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 114
