跳转到主内容
Computer freezes with display replacement [updated]
Original issue: We recently replaced the display on this MacBook. After installing the replacement, when we screw the bottom casing back on and use the computer, the entire system freezes (display stays on, nothing moves, won’t go to sleep).
However, if we leave the two screws in the top corners of the bottom casing out of the machine, it works perfectly. Also, it works perfectly in safe mode regardless of whether the two screws are installed or not.
The screws in the corners are the correct length. An SMC reset and NVRAM reset didn’t affect anything. I can’t for the life of me understand why those two screws would have anything to do with it, is it just coincidental or is something going on?
Update: So perhaps the screws were just coincidental. We just booted it up with the bottom casing on but not screwed in, and it still froze after around a minute. We are going to reinstall the operating system and see if that helps at all. Intermittent problems are the worst :)
Update 2: Disabling login items and reinstalling the OS (on top of the existing install) didn’t help. If we don’t boot in safe mode it freezes a minute or so after boot regardless of whether we login or not anyways.
Update 3: We put the old display back in the machine and it no longer freezes at all. So I don’t really understand this issue. What would cause a MacBook to freeze randomly with a replacement LCD (Apple OEM part of course), but not in safe mode? And somewhat intermittently?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I had same exact problem. I fixed it by changing the LVDS. its working like a charm now. Thanks Dan!
完成的
添加一条评论
1个答案
Check your logic board screws you may have installed a long screw where a short one is required. Check the screws as listed in 交换MacBook Pro 13'' Retina显示器2013末期版本的主板 in Steps 14 & 31 getting mixed up.
这个答案有帮助吗?
得分 0
4条评论:
All those screws are as they should be. She wouldn't have removed those components to do a display replacement anyhow.
完成的
Someone else could have ;-}
Any dents in the cover? Is the case warped at all?
完成的
@danj Aha true true, although it wasn't happening before this replacement. No dents or warps in the cover or casing, it fits on normally.
完成的
mmm... sounds like the display assembly has an issue. Lets try this carefully plug in the iSight cable from the new display in with the original display still connected via the LVDS. Is the system stable that way?
完成的
添加一条评论
添加你的答案
Jonah Aragon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 84
