My wifi is greyed out after a fall
everything work fine, tried the hard reset and all, but i have no experience with where the wifi cables and etc. is and so i wont dare to try to open and check before being sure of what it is.
Greyed out Wi-Fi on the iPhone 6 after a drop would defiantly be the Wi-Fi chip. This repair would require microsoldering. The repair cost would be around the price of another iPhone 6.
这个答案有帮助吗?
Could it be something with the wifi IC?on top of the left corner? that needs to be replaced? like any chance?
No. If the Wi-Fi wasn’t greyed out you would be looking at cables and antenna but since it is greyed out you would have to remove the Wi-Fi chip reball or replace it. It’s not an easy job as pads usually come off with the chip which requires the running of jumper wires.
i see, so the motherboard is the culprit, will it get fixed if i change the motherboard?
The screen is black but when i shine light on it i can see the apple logo etc.
That means the phone may also have a no backlight problem. With both those board level repairs combined it's like what was said, same as another iPhone 6.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 64
