Instapot mini got wipedout with wipedown
I gave my Instapot mini a wipedown after nearly a year of use careful not to get water into the devise. Apparently I was unsuccessful as the mini never returned to working order. What needs to be replaced & where to procure the part?
What does your Owner's Manual say? I see two units on Amazon for $50/$60. Probably end up more trying to fix the unit. Have you taken it apart to see if there is any obvious damage or malfunctioning component? If you suspect water damage to the interior have you tried disassembling and drying out the unit with say a hair dryer?
由 prop man 完成的
