MacBook Air 4,2 with broken Th1H and Ts0S sensors
I have Macbook Air 4,2 with broken Th1H and Ts0S sensors. They show -127 C. How can I find replacement parts and fix them?
Sensors are not parts that can be replaced, they are inside the logic board. Unfortunately that series is plagued by problems at PCH and memory and although some techs reported some success with reflowing, I’d not recommend it unless one does the attempt for himself in his own kitchen oven. A replacement board, given the age and history of that series, carries risks it will show the same issues sooner or later, be aware of that in your decision making.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 155
4条评论
@bcursor
Th1H Heatpipe 2
Ts0S Memory Proximity
由 oldturkey03 完成的
Thanks a lot. I think I need to replace my logic board?
由 Mücahit Şenol 完成的
@bcursor give it a bit of time. I am certain others will look at your question and will come up with some great ideas.
由 oldturkey03 完成的
Is this problem causing the machine not to work correctly? What are the effects of these failed sensors?
由 mayer 完成的
