跳转到主内容
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
170 个问题 查看全部
Can the ram be replaced even its soldered to the motherboard?
Can the ram be replaced by desoldering it and soldering on new memory?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
最有帮助的答案
With the right skills and tools anything is possible!
Sadly, replacing the RAM chips on the logic board here is not something a DIY can do. Between the cost of the tools and parts it would be much cheaper just to replace the logic board Mac mini A1347 (Late 2014) Core i5 1.4 GHz Logic Board.
Frankly, I would just get one of the newer 2018 models with the amount of RAM I needed.
Mac mini A1347 (Late 2014) Core i5 1.4 GHz Logic Board图片
产品
$174.99
这个答案有帮助吗?
得分 1
添加一条评论
Just a thought. Are you sure your unit has soldered in RAM (if indeed it's a Mac mini 2014 that is)? According to the following link from 6 years ago the RAM is not soldered in.
https://www.youtube.com/watch?v=wF5mz---...
这个答案有帮助吗?
得分 -1
评论:
@propman - The CNet vid is on the 2012 model which did have accessible SO-DIMM RAM Mac mini Late 2012 RAM Replacement.
The 2014 has soldered RAM! I know Apple really stepped in it! Apple realized they messed up and went back to serviceable RAM in the 2018 model! Mac mini Late 2018 版内存更换
完成的
添加一条评论
添加你的答案
Keith Wade 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 17
过去的30天: 82
总计 1,722
