跳转到主内容
修复你的物品
维修的权力
配件 & 工具
2.26 or 2.4 GHz / White plastic unibody enclosure
732 个问题 查看全部
I tore a tiny little connector out of it's socket. What do I do?
I tore this miniture connector out of it’s socket on my Macbook Unibody A1342, it looks like it goes to the fan and I’m really scared that it’s going to goof up the laptop. I’m attempting a motherboard replacment and I needed to disconnect it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Putting on Magical Remote Viewing Glasses to view "it looks like it goes to the fan". Nope not seeing anything. Maybe my Glasses are broken and I should post a query about the problem on Ifixit. Ohhh, I will have to remember to include a photo or two of the actual damage so that participants get a clear concept of the situation. :-)
完成的
@propman Oh no prop man, we're supposed to waste an hour guessing what it is.
完成的
@mayer lol! ain't that the truth!
完成的
@propman you have been around long enough and given enough quality answers to do a decent profile and pick a real avatar so we get to know you some and can spot you
完成的
@mayer Will keep that suggestion in mind. Thanks for the kind words. Appreciated! :-)
完成的
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
1个回答
最有帮助的答案
Is it the connector that’s on the end of this fan?
MacBook Pro 13" Unibody and MacBook 13" Unibody Fan
Apple Part Numbers (any will work) 922-8620, 661-5418, 661-9530, 922-9530, 661-4946
MacBook Unibody Model A1342 Fan Replacement
UPDATE 9/1/19
Since I know know it is a two wire cable, it is most like the Speaker connection
MacBook Unibody Model A1342 Rear Speaker Replacement
MacBook Unibody Model A1342 Fan图片
指南
难度:
中等
10 - 30 minutes
MacBook Unibody Model A1342 Rear Speaker图片
指南
难度:
中等
15 - 55 minutes
这个答案有帮助吗?
得分 2
评论:
No. It's this tiny 2 pin connector. Sometimes it snaps back together but falls apart when moved.
完成的
Probably goes to the speaker if it is two pin.
完成的
Thank you. That's not as bad as I thought.
完成的
添加一条评论
添加你的答案
mrmanman 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 2
总计 36
