Why is my washing machine leaking after replacing drain pump?
There was a small leak at times. None of the hoses were clogged. Coin trap was clean. We had to drain it from emergency drain tube after each load. Decided it must be the drain pump. Replaced drain pump. Now water is flowing out of the bottom at the beginning of the cycle.
Might give participants here a better grasp of your situation if you included the manufacturer/model # of your unit. If applicable, you can also add some photo's. See the following link on information on how to do that:
在已经存在的问题里加入图片
由 prop man 完成的
Thanks. It's a Samsung WF42H5200AW/A2-0001 front loader. Water seems to be coming out of the coin trap. None of the hoses are wet so they aren't leaking or broken. What could this be??
由 Nira P 完成的
