跳转到主内容
海尔制造的笔记本电脑的维修和支持指南。
120 个问题 查看全部
My laptop keyboard not working
when i type any letter it is deleted
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your backspace key or the contact underneath is likely stuck or dirty. I would look up your specific computer for recommendations for your keyboard but most times a key can be carefully removed from the keyboard by prying with a spudger and then cleaned. I would use a quetip and a small amount of isopropyl alcohol to clean the underside of the key, the plastic/metal brackets that hold the key in place, and the contact if possible.
这个答案有帮助吗?
得分 0
3条评论:
My laptop some keys are working while others are not...Kindly recomend what wil i do?
完成的
keys like enter, ALT , B T Oetc..
完成的
Same process outlined in the answer to clean them. Otherwise, you can disconnect the keyboard wire connector, examine both the connector and the cable pads cleaning where necessary, then reconnect and test. If that does not work the keyboard should be replaced.
完成的
添加一条评论
添加你的答案
saif urrehman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 176
