跳转到主内容
修复你的物品
维修的权力
商店
发布于2017年3月3日,任天堂 Switch 是一款可以在电视和路上玩的掌机。
337 个问题 查看全部
How to test Nintendo Switch motherboard and battery - unknown conditio
Hi there :)
I’ve purchased few not working Switches and trying to create just one good one.
what is needed to connected to motherboard to be tested.
at the moment I got connected LCD and touch screen and battery - on display I just see battery symbol only and “lightning”
it is charging with about 0.46A for about 10 minutes and nothing
is it normal or battery was so discharged I need to wait 1 hour?
chip is warm in touch but can it be burned if no radiator and fan if it will switch on?
if motherboard (or charging chip) would be broken - would I see that battery symbol?
thank You for help :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
Typical the charging ports goes bad on this model even if it looks good and shows the lightning has to be resolder with a new one
source: I do it everyday
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bart 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 7
过去的30天: 30
总计 191
