跳转到主内容
焊接是通过熔化另一种金属将两块金属连接在一起的方法。 焊接有很多种,但本文旨在教您电焊的基础知识。
56 个问题 查看全部
Is this recoverable? (Broken Pads)
After laughing with my stupid mistake.. Can this nand be fixed?
This is an iPhone 7 128GB NAND Flash (phone was locked). I accidentally broke the pads while removing it. I also tried scratching the pads a bit, thinking that i could solder there (might have made things worse). However, testing with my multimeter for continuity.. every scratched pad, is now connected to each other.
The reason why i removed the nand is because i bought a U stick, and i was hoping of making a usb out of it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Depends on how much time you want to invest in this.
If you’re not trying to recover the data from the NAND, I would personally not pursue it, at least for commercial reasons. If it’s a personal project, then have at it and continue to learn.
这个答案有帮助吗?
得分 1
1条评论:
its for a personal project.. do you think that soldering on the scratched pads will burn it?
完成的
添加一条评论
添加你的答案
Yannis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 84
