跳转到主内容
Guides and repair information for the Lenovo Thinkpad T430, a 14-inch business laptop by Lenovo.
25 个问题 查看全部
Fermat laptop lenovo thinkpad T430S
I need to explain how to fermat my personal computer which is Lenovo Thinkpad T430S and convert it from Windows 7 to Windows ten
Please help and thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
to format your local disk, use the installation DVD of new windows, or the same. If you will want to install a new windows, the installation guide will offer you to separate disc, or clean up your disk before install a new version of windows. It’s the best way and your data will be deleted permanently.
Ofc, you can delete your datas manually, but it takes a long time, which you can spend by drinking coffee. Also, if you created recovery point in the last (in the beginning of installation Windows7) you can turn your computer back and then you will lose all your datas - but it may not work.
So, insert installation disc of Windows 10, let the installation guide delete all your datas and software from you HDD and then install a brand new version of Windows 10.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tech mack 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 108
