跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
charging issue while try to charge using usb cable in car
When i try to charge my S8 plus in my car using usb cable instead of charging its taking off my charge, it used to work fine till 3 months ago and i don’t remember doing anything new with my phone or car. I even tried with my original cable that i got with phone but its still the same but it works fine inside the home even with the usb cable that i bought to charge in my car. wonder does anyone had this issue and how its resolved….
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
If your car USB port isn't charging your phone, the problem could be with the port, the cable, or even the phone. Not all car USB ports are designed to charge phones, or power peripheral devices at all, so there's a chance that you're dealing with that type of situation.
这个答案有帮助吗?
得分 0
1条评论:
as i mentioned it used to charge and work perfectly till 3 months ago, this issue started all of a sudden the funny thing is i tried in my other car and its the same issue before all these started to happen it used to work fine in both cars, not sure what went wrong its started behaving wired with both cars to add more to this my wife have S8 and its the same with her phone too...
完成的
添加一条评论
It sounds like a blown fuse in the car. Check your fuses for the USB charging port or cigarette lighter of the car, depending on where you have the phone plugged in to charge. The fuses are typically located under the hood, on the left of the driver just below the dash or in the dash, and sometimes you need OR to identify whether or not the USB port or cigarette lighter are working, try plugging in another device that is known to work.
There’s another item to touch base on here which is the charge cable itself. While this may not be at fault here, it is always recommended to use only original equipment charge adapters and USB cables. I have seen generic/cheap chargers work fine sometimes and others have completely fried the cable, the charge port of the phone, or the charging chip on the logic board of the phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jay sanala 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 40
总计 4,197
