跳转到主内容
The Samsung Chromebook 3, introduced in 2016, is the successor to the Chromebook 2 and features an Intel Celeron N3050 processor and 4 GB of RAM and 16GB of storage.
3 个问题 查看全部
Why does my Chromebook restart randomly?
For some reason when I’m watching a video or playing a game on my Chromebook it restarts out of nowhere. I already powerwashed it but it still does it. But guest mode seems to work even though you can’t download games on guest mode. Can you please tell me the solution? Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Is it your own personal computer, or is it shared by any sort?
完成的
It is my own computer.
完成的
I probably need a new Chromebook.
完成的
添加一条评论
1个回答
Watching videos and playing games on your Chromebook usually uses a lot of power. This can make your computer overheat and restart. Perhaps this only happens in Administrator Mode because Guest Mode doesn’t have as many rights to your computer’s resources (like downloading, etc.) and therefore uses less power?
Since charging your Chromebook can also produce heat, try playing the games without it plugged in and charging. If it still restarts, you may have to continue doing what you have been doing do far - downloading the media content as an administrator and then playing the games in Guest Mode.
这个答案有帮助吗?
得分 0
评论:
When I was trying to read what you said it restarted then it restarted again. Then again my Chromebook is one year old.
完成的
I don't how to do the admin part I'm only in middle school.
完成的
添加一条评论
添加你的答案
Preston 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 210
