跳转到主内容
修复你的物品
维修的权力
配件 & 工具
这是 MacBook Air的维修指南,MacBook Air是Apple的一款面向消费者的笔记本。
3615 个问题 查看全部
MacBook Air only turns on when plugged in (water damage possibly)
I spilled some water onto the keyboard of my 2016 11” MacBook Air. I had let it dry but now it only turns on when the laptop is plugged in. If the cord is taken out, it immediately shuts off. Also, when I plug the charging cable into the side of the computer it automatically turns on without pressing the power. It doesn’t turn on from batter power at all.
This happened a few months ago and initially the battery power wasn’t dropping but it isn’t charging. Just recently it says, “Replace battery”. It says the current charge is 870 mAh and the full charge capacity is 4,737. The design capacity is 5,100 and it says that at max charge it can hold 93% of it’s original charge. It has been through 169 battery cycles but it says the macOS battery status is “poor” and that it is charging with “0” watts.
What should I do. I feel like the battery might still be good but for some reason it isn’t charging the battery when I plug it in, or letting me run off of the battery. The battery is just slowly draining as time goes on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
Shorted/damaged PMIC? It may be able to provide the system with juice to run, but not enough to charge the battery. If you want, you can try popping the bottom off, and taking a peek at the mobo/battery for any obviously damaged parts.
Good luck!
这个答案有帮助吗?
得分 0
评论:
Ok thank you. Is that part pretty easy to spot? I will try picking up a set of tools to crack it open today or tomorrow.
完成的
Which generation of Macbook Air is it? (Which year?)
I'm going to find the teardown mobo shots and see where the PMIC may be.
完成的
添加一条评论
添加你的答案
TTwinTTurbo 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 23
