Won't Turn on After Replacing Battery
I replace the battery on my Gear S3 Classic. I followed some video and had no issues. I've dealt with this kind of stuff before.
The charging screen comes on when I place it on the charger and it seems to react when I push the back button. I mention this because it doesn't do anything at all when I hold down the "Home" / power button.
I've researched a good amount and saw that some people have success with holding both buttons, holding the Home for 10 seconds, and of course checking all of the connectors. I have also tried using the original battery.
Of course, I've had no luck with any of these. My current guess is that the home button is not working anymore for some reason.
Has anyone had this issue and if so how did you fix it?
If not that, could someone link me a resource to learn more about the insides of the watch so I can continue troubleshooting it?
Thank you!
I'm in the same boat and seems to be a common theme yet years later still no one has an answer. After fiddling around and trying to clean every connector, I broke the power flex cable. I'm going to try to replace that as well, and see if that has any effect. Anyone else had any luck?
由 Justin Lalonde 完成的
For some reason I only see people having this problem with the gear s3 classic.
I have the exact same problem. I guess I'm going to try and put the old battery back in. If I find a solution, which is unlikely as no one has for the past 5 years of formums I found, I will post it.
由 Zach H 完成的
Just curious is it the motherboard issue? Because I facing the same issue as well. Look online trying to buy 1 motherboard to try changing it
由 Milton Ng 完成的
