跳转到主内容
加入维修社区 - 创建账户
A point-and-shoot camera by Kodak released in 2006.
When I turn on my camera it shuts automatically.
When I turn on my kodak easy share z650 it shuts down.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
It turns on then it turns back off help
完成的
添加一条评论
2个答案
最有帮助的答案
Camera specifications for the batteries required by this unit are:
Kodak NiMH battery pack KAA2HR, or 2x AA
If battery pack is installed try using a couple of regular AA size batteries to make sure it is not just a charging problem. If camera works with regular batteries, then battery pack and/or charger could need replacing.
If camera still not working after testing, a visual inspection of the camera's interior components may be of use. A teardown tutorial can be accessed at this location:
Kodak Easyshare z650 Teardown
这个答案有帮助吗?
得分 1
添加一条评论
Terri Jones if the check by @propman doesn’t help you want to check the lens. It is not uncommon for these cameras to shut down because of a lens error. Check on here for some possible solutions.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Terri Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 3,974
