跳转到主内容
修复你的物品
维修的权力
配件 & 工具
2.26 or 2.4 GHz / White plastic unibody enclosure
720 个问题 查看全部
Can somebody recommend a lightweight linux distro for my device?
I’m almost done fixing up an old Macbook Unibody A1342. I’m going to install a lightweight Linux distro on the device because while I was fixing it, I decided to install a 128GB SSD (which has no OS installed onto it) to speed up the device. Any suggestions?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Terminal/server editon would be lightest as there is no Desktop (unless one adds one to the server edition anyways). KDE desktop with all it's bells and whistles would be the heaviest.
Desktop choice is purely user preference. Suggest you download and try various ones via using an ISO file and bootable usb stick (or install them all to the SSD and then pick which to choose at boot time.)
If you are looking for a starting point then Debian/Ubuntu/Linux Mint maybe a good choice. Linux Mint is based on Ubuntu and Debian and Ubuntu is based on Debian releases. They all have various desktop flavors available; Linux Mint has their own too called Cinnamon (which I am using right now).
With 4 Gigs of memory, KDE is the only one that may give you some slowdown; again it depends entirely on what software is running by the user.
Might want to check out https://distrowatch.com/ which has loads of info and all the web addresses for the numerous linux distributions.
完成的
@propman Thanks for your help!
完成的
What are the specs? Is it 32bit or 64bit?
完成的
@jessicapfawkes I suspect it is 32 bit. The device was made in 2010.
完成的
What are you planning to do with this? You could turn it into a chromebook:
https://www.neverware.com/freedownload
I believe it's compatible, but I'll check the list.
完成的
显示更多的5条评论
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
2个回答
已选择的解决方案
Have you tried turning it into a chromebook? Neverware has a pretty decent version, and also gives instructions on how to do the install on a mac.
这个答案有帮助吗?
得分 1
评论:
Looking into that right now.
完成的
I'm getting the logic board for this macbook in the mail pretty soon. If this OS works well on it I'll accept your answer (: Thanks!
完成的
Can I run this on a USB stick? I need to see the functions before I install it.
完成的
Tried it on a usb stick. Looks perfect for my device. Thanks for your help!
完成的
添加一条评论
Here is a link for lightweight linux systems. Although the list states Atom processors, these distributions will have other versions.
https://www.makeuseof.com/tag/5-lightwei...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mrmanman 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 62
