Why can I not connect my printer to the network
My printer is connected to my computer via cable but i want to connect it to our network
Hi,
If you are sure that the model number is a Brother MFC 7340 then you’re out of luck as it doesn’t have a network option.
Brother network enabled printers have a N or W at the end of the model number.
You’ll notice on the cover page of the user guide for your model that there is no letter after your model number.
Here’s an image taken from the user guide which shows the network specifications for the models listed in the guide. Yours is not there.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
Ok thanks i thought i could run the network through my computer but i guess not
Hi,
If your router has a USB connection and the right options, you could connect the printer to the router and use it that way.
Here's some information on doing it that way.
Alternatively if the printer is connected to a Windows PC you can turn the PC into a print server.
I don't know Mac so the option may be there for them as well if your printer is connected to a Mac.
There may be more online this was just a quick search ;-)
Normally, people get the brother printer not connecting to wifi problem due to the network settings or router settings issue. here are the steps to fix the problem.
这个答案有帮助吗?
Have you installed the printer software?
Is it enabled and shows in your computer?
Is the printer wifi enabled?
这个答案有帮助吗?
Yes I did install the printer software but the printer is not wifi enabled
过去的24小时: 12
过去的7天: 33
过去的30天: 177
总计 2,742
Hi,
What is the model number of the printer?
由 jayeff 完成的
Brother MFC-7340
由 LakeM0nst3r 完成的
