跳转到主内容
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 个问题 查看全部
My phone doesn't boot (red led)
My phone started shutting down by itself many times during the day and also it became very hot.
So I decided to recover it through the Sony companion app. I did it many times because it never became usable but it turned black and now it doesn't show anything on the display and it isn't recognized anymore by Sony companion because it doesn't boot in download mode.
It can also be that it is dead in the middle of a recover done through Sony companion.
Now, if I connect it to the charger (or to the pc), it shows the red led for a while and it turns off. It seems that the phone “turns on internally” and then it turns off the red led.
If someone knows what is the problem and can help me, thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would think it would be that your battery is faulty and you need it replaced
Your symptoms point to the battery been faulty
Before this accured was your battery draining very quickly If so another symptom that points to the battery
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your opinion
完成的
添加一条评论
添加你的答案
ALBERTO PASQUALETTO 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 101
