跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2693 个问题 查看全部
Touch Id not working when screen is placed, but works while it's open.
Vague title, I know. Iphone 6s: Just did a screen replacement on a friend’s 6s, everything normal, took good care, used correct tools, home button works fine, but touch Id doesn’t. Tried everything but couldn’t get the %#*@ thing to work (no notification on phone saying touch id needed repairs), decided to lift the screen and to my surpise, touch id only works while the screen is lifted from the case, the moment I try to shut the phone closed it doesn’t work anymore. Any ideas? tried to losen some screws and protectors, also took screen apart (back panel, flex cable, home button) then install again but didn’t work.
Thinking on trying a new screen, any suggestions?
Update (08/21/2019)
Problem solved, it was the screen I was using, changed that and worked like a charm.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Probably a pinched cable. For what ever reason cables on the iPhone are really sensitive if you pinch them in just the right spot. Could also be an issue with the screen but more than likely it’s something pressing on the button or a ribbon cable when the screen is pushed down. Is the frame bent? Bent frames will keep the screen from sitting correctly putting pressure in areas it shouldn’t be.
这个答案有帮助吗?
得分 0
1条评论:
Hi! no, the case is not bent, might be pinched cable, going to reassemble and see if that helps
完成的
添加一条评论
添加你的答案
Daniel Guerriero 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 31
