跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
3d touch doesn't respond
Replaced the iphone 8 screen and 3d touch is totally unresponsive. Took the screen back off, checked all the connections, and it still won’t respond. Also tired adjusting the 3d touch settings, and a hard phone reset, but nothing helps! Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Try putting your old screen back on. If it works then at you need is a new screen
这个答案有帮助吗?
得分 0
添加一条评论
Could be the quality of the new screen. Where did you get it from? If it’s a cheap screen off of Amazon there’s no telling what you may get in terms of quality. Did you check all the cables? Make sure nothing is pinched or that any pins got bent. Apple could have also just decided to disable this feature with a software update if it detects a non genuine Apple screen. Doubt that’s the issue but with Apple you never know.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh Hixson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 83
