跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
97 个问题 查看全部
Changed Battery on dead Ipad and It won't turn on or charge
Ipad Pro died and would not power back on or take a charge. After using a smartmod tristar tester to rule out hydra/tristar chip I went ahead and ordered a new battery and replaced it. This however did not remedy the issue. While plugged in the ammeter is at zero but will very briefly jump up to 1.07A and then drop to zero again about once every second or two. The battery voltage reads at 3.82V and while the battery is removed if I connect the lightning cable and test the connections to where the battery “plugs in” I can get around 1.3V but it does fluctuate wildly.
I guess my questions are how many volts should i be getting at the battery connection while plugged in and any thoughts on what the actual problem is. Also is there a better way to test the charging port since it soldered on the underside of the board and Id like to make sure that power is at least making it through to that point (even though the tristar tester did give the dock a pass). Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
1个回答
You must’ve got a bad battery. If it won’t turn on that’s because the battery is dead. If it won’t charge that’s because the battery has an issue and isn’t taking in the charge.
这个答案有帮助吗?
得分 0
评论:
Forgot to mention that we ordered 2 batteries and tried them both. They both test fine with the multimeter (3.8V) so as much as I'd love for that to be the case I'm having my doubts.
完成的
@benobee Oh. This could be a number of issues. Does ANYTHING power on? Do you hear the speaker, or see a flicker on the display? Maybe something that charges your device stopped working? It's hard to rule out anything for sure.
完成的
@conzo I get no signs of life what-so-ever. Which I'd think with a battery testing at 3.8V I should at the very least get a dead battery sign when I go to power on. and also nothing when I plug it in... Do you know anything about these smartmod tristar testers? how reliable are they when it comes to diagnosing a bad dock? And just because tristar passed could we still be looking at PMIC? The owner says she never unplugs it, sits on her end tabel next to her chair and has been plugged into the original cable since she got it, which is another reason I thought battery but maybe that is hard on other components as well? What is the best way to test the power as it travels from the dock to the battery connector and is the 1V I'm reading at that connection a concern? should it be higher? Thanks for your time and your insight!
完成的
@benobee Reading 1V? I don't know if that's normal or not, but my S4 has a 3.8V battery. Maybe some kind of faulty if gate or not gate on the logic board is triggering a resistor and limiting the voltage to much, but I do belive you could get a battery flat symbol with 1V. I'm very confused about this problem.
完成的
添加一条评论
添加你的答案
Benjamin Oldemeyer 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 34
