跳转到主内容
加入维修社区 - 创建账户
2017 年 9 月 22 日发布。型号 A1864、A1897。有 GSM 或 CDMA 版本可选,存储空间为 64 GB 或 256 GB,颜色有金色、银色和深空灰色。
Rear Camera & Flashlight Not Working
I realize there are a lot of topics on this issue, but I’m looking for some information specific to an iPhone 8 Plus.
I acquired an iPhone 8 Plus that was an absolute MESS.
I had to replace the back housing, screen, charging port, battery, and numerous brackets/screws.
Surprisingly I was actually able to get it working. However, the rear camera only shows a black screen and the flashlight doesn’t work.
I replaced the mute/volume/power flex cable which did not fix the flashlight.
Am I understanding correctly that if the rear cameras are broken, then the flashlight function will not work either? Just trying to figure out of it’s worth purchasing replacement rear cameras or if this could be a logic board issue.
Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
7个答案
已选择的解决方案
I can only speak for the iPhone 8 at this point, but I have no reason to believe it would be different for the iPhone 8 Plus.
The camera and flash ARE synced on an iPhone 8. If the camera isn’t working, neither will the flash.
One more note regarding iPhone 8: There is one screw on the logic board that is covered by a rubber pad. You need to scrape/remove that rubber pad to access the screw. In my situation, some of that rubber residue ended up blocking the camera contact on the logic board which prevented it from securely connecting. If anyone is experiencing similar issue after disassembling an iPhone 8, this is worth checking out.
这个答案有帮助吗?
得分 4
1条评论:
I'm having the same problem with an aftermarket housing. I think the problem is caused by the standoff screw which secures the cameracover.
I think it makes part of a circuit. On the camera bracket there's a metal ring missing. Does anyone know if the camera housing should be grounded to the housing?
由完成的
添加一条评论
Hey!!! I had the same problem afther a frame replacement.
The problem I had is that the screw that is just above the camera connector, made a short to ground since it touched the metal of said connector, I removed the screw and it began to work.
这个答案有帮助吗?
得分 3
3条评论:
Can confirm this resolved my issue or rear camera and flash not working, thanks!
由完成的
This solved the issue for me after trying to find a solution for over an hour. That %#*@ screw...
由完成的
You are a hero, switched almost everything, this was it
由完成的
添加一条评论
What is the location of the offending screw?
这个答案有帮助吗?
得分 3
添加一条评论
Do you have a spare camera ?
I know that on iphone 6-7 backcamera and flash has a connection, by replacing the back cammera the flash will work.
这个答案有帮助吗?
得分 0
3条评论:
I don't have a spare camera, but think I'll have to gamble and purchase one.
What is even more bizarre is I also have an iPhone 8 which I also replaced the housing and screen on. I know for a fact that the rear camera worked. This morning I sold it, the buyer restored their own backup, and now has the exact same issue with the camera/flash.
This can't just be a coincidence...
由完成的
Did you figure it out mate ?
由完成的
im having the same issue . Any help on that ?
由完成的
添加一条评论
Has anyone been able to sort this out ? I've done the exact same thing and my back camera has a black screen . Please !&&* thank you . On the iPhone 8
这个答案有帮助吗?
得分 0
1条评论:
Same here, what can i do ?
由完成的
添加一条评论
You might have some problem with the camera circuit that causes that issues. I also solve those issues to many this may help you to fix that issues.
这个答案有帮助吗?
得分 0
1条评论:
This is super unrealistic that anyone would actually do. 9/10 times it's just the offending screw. Look at the answer above and remove that screw. Then re-test.
由完成的
添加一条评论
In my case the flash works but rear camera is not working can anyone give a solution please
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 47
过去 30 天: 107
总计 29,847
