Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
Gang Gang @ganggang66530
声誉积分: 1
发帖于: 2019年8月20日
Everytime I try charging my headphones the red light doesn’t turn on and they won’t turn on anymore.
这是一个好问题吗?
Gang Gang follow the advise from @propman after that you also want to consider replacing your battery.
由 oldturkey03 完成的 2019年8月20日
prop man @propman
声誉积分: 1.1千
3
Sounds like you need to do some troubleshooting with a multimeter to check voltage levels coming from your charger and also disassemble the headphones to make sure the charging port is ok, correct voltages are present etc.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,517
1条评论
由 oldturkey03 完成的
