跳转到主内容
修复你的物品
维修的权力
配件 & 工具
2.26 or 2.4 GHz / White plastic unibody enclosure
737 个问题 查看全部
Why does my device begin to boot then shut down?
I found an old Macbook Unibody A1342 in my basement and I’ve been trying to get it working. I’ve tried booting from a flashdrive but had the same problem. I don’t think it’s the display because I hear the fans stopping and there’s no OS sound. My device also does not charge to 100%, which led me to thinking it was the battery, but I can’t boot by just unhooking the battery and plugging in the charger.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
It only boots to the apple logo and shuts down before showing loading bar. Same result on ubunto flash drive.
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
In my experience most A1342 with issues have had some spill on keyboard which on that machine sits in a tray like plastic seal cover. I would try disconnecting the keyboard and try to start off jumper pads to start with.
这个答案有帮助吗?
得分 1
评论:
Thanks, I'll try that!
完成的
Update: It might not work. The person who used to own it said that it just fallen off their bed and stopped working, but I'll try.
完成的
Which connector is for the keyboard? I tried one that looked like it ran under but not too the battery, same result.
完成的
I've never repaired a macbook before :P
完成的
It booted up like that but turns off as soon as I remove my GPIO wire (I assume that's normal). It's hard to hold the wires long enough to see if it will keep working, though.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
mrmanman 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 47
