跳转到主内容
Released on July 28, 2014, the Samsung Galaxy S5 mini is a cell phone that features an 8 MP rear camera, 720p display, fingerprint scanner, and water resistance. It has a larger display, increased battery life, and an updated camera from its older brother, the Galaxy S5.
30 个问题 查看全部
Hardware -problem, loose connection? Phone restarts frequently
My smartphone frequently blacks outs and either restarts immediately or doesn’t react untill I boot it up again. The problem is reproducible as the phone shuts off when I lightly tap it on the table as if I wanted to just put it down. (so, very light “shaking” already does the trick)
Either way I just noticed that it shuts down laying on the table not being touched at all, too.
Could it be some loose connection or a battery problem? I just purchased a new battery but it won’t arrrive until Thursday. Current battery is on 100%, loading was not a problem or strange at all. The phone is currently plugged in, too, but the problem remains.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello San Schmidt,
this does not seem to be a hardware problem. I use a Samsung Galaxy S5 Mini as my main device too. I had the same issue. Sadly there are no official updates of fixes available. But you can flash custom firmware, to solve the problem. I installed a new operating system and the problem was gone. Be aware that if you do this, check your guarantee.
Best Regards
Max
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
San Schmidt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 54
