跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE that won't boot
I have an iPhone SE that will turn on and show the Apple logo (then a blank screen,) but that’s it. I have tried to put it into DFU mode (successfully,) but when I hit restore, the Apple logo gets a progress bar underneath it, but does not progress. I have left it overnight and it did nothing but sit there at the logo with an empty progress bar. I have to reset it to get it off that screen.
In Device Manager, three devices show up indicating that the phone is in DFU mode by default, but I can’t get to the restore options unless I hold the home button and power button as is required for normal dfu mode.
I don’t know what else to try. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You may not have a software problem
It is possible you have a hardware issue with the logic board
If you have a good SE phone and if you can transfer the logic board fron the phone that is not working to it and see if you get the same issue
这个答案有帮助吗?
得分 1
2条评论:
Sadly, I don’t have a spare.
An easier fix would be much more preferred. ;)
完成的
This really is the only way you be able to find out if you have an issue with the logic board You fault is one that you need to break down in sections Eliminating Other wise bring it to a repair shop
完成的
添加一条评论
添加你的答案
Jared Luker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 72
