Repair and disassembly guides for HP PDAs.
11 个问题 查看全部
HP ipaq rx3715 factory resets every time I restart it
Hi all,
Whenever I power down my PDA, it factory resets itself. As in it forgets all of my settings, however I haven’t tested to see if it wipes the files too.
It might have something to do with the fact that it seems the only way to power it off is unplugging and removing the battery, and it therefore might not be saving the settings. (yes I tried holding the power button down, it just turns the screen off, doesnt actally power off).
Anybody know how to resolve this issue?
Also, I would like to know if there’s a correct way to shut it off. Thank you!
Add a comment
Android 维修工具包
一个新的屏幕或电池就在一个套件之内。
现在开始购物
Android 维修工具包
一个新的屏幕或电池就在一个套件之内。
现在开始购物
Most Helpful Answer
Hmmm.....according to this blurb there is a switch associated with the battery cover. Apparently the unit will turn off if this switch isn't engage correctly by having the cover install correctly. Might want to try removing the cover rather than removing the battery to see if it is only going into sleep mode or if it really does go off and save your settings. Seems that whole family line only has a sleep mode function. Anyway just a thought
http://www.fixya.com/support/t1507593-hp...
Score 1
Add a comment
It has been a while since I had checked this post. It seems that it should not be resetting data whenever power is lost, it should only do that when it is hard reset. I think it may be a firmware issue but windows for some reason blocks the active sync program from installing because “it decreses system security”, and it seems windows is committed to keeping me from doing what I want.
Add a comment
Add your answer
Connor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 16
