跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
582 个问题 查看全部
iPad Air 1 home button pad missing
I have ordered a replacement home button for the iPad Air 1, but upon receiving it, i noticed the small central pad in the middle of the button is missing from the replacement part. This pad is the part that pushes on the actual switch. The first picture is the button I received and the second is the one in the ifixit page showing the pad I’m talking about. Is my button defective or Am I missing something when ordering replacement parts? I appreciate any help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
As long as the button you received can actuate a click of the home button you should be good to go. If not, try to find another seller with a higher quality part.
这个答案有帮助吗?
得分 0
评论:
If not the middle of the black metal bracket that sits behind the home button can be bent inwards to get it to click sometimes.
完成的
Thanks, I have ordered the replacement button from 2 different sellers and none of them have the central pad. It turns out the button does not actuate the switch in this condition.
完成的
添加一条评论
添加你的答案
Rodolfo Granados 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 56
