跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2687 个问题 查看全部
Why is my iPhone charging backwards from 20% to 1%?
So my iPhone 6s had a dead battery and wouldn’t turn on even if u charge it so I decided to go to a local mall to fix it and when they fixed it, it was at 39% and then I started to realize the battery kept going down really fast and when I finally got home it was around 20% something percent and it kept charging backwards dropping and dropping now it is 1% I’m not sure what to do. Should I go back to my local mall and waste money to get it fixed again? I don’t know what’s wrong with my phone?? Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
The store you got it repaired from should have warranty, at least 30 days.
Explain to them about the problem and hopefully they will help you out as that sounds like a bad replacement battery.
这个答案有帮助吗?
得分 3
添加一条评论
omg I had the same problem ! I read another article and it mentioned that you can get it to work again by moving the top of the charger where the charging port is? I gave it ago and it seems to be working perfectly fine again. Give this a go.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem
这个答案有帮助吗?
得分 0
添加一条评论
It sounds like the tristar chip is bad. Take it to a repair shop and have them test the tristar chip. You can buy a tester they are about 130 plus dollars. I believe ifixit sells them. They usually go bad from using aftermarket chargers that aren't MFI Certified. You can put in a new battery and it will work fine until the battery dies but it won't recharge.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jammy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 2,642
