跳转到主内容
雪佛兰汽车的修理和支持指南。
1367 个问题 查看全部
Why does my radiator fan only come on when I put my aircon on? sonic
chevrolet sonic 1.4ls. why does my radiator fan only come on when i put the aircon on?
If the aircon is off, the radiator fan doesn’t come on and the car overheats.
I have to drive the car with the aircon on all the time.
I changed the temperature sensor switch, didn’t help at all.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @faiz1 ,
Have you checked that the coolant thermostat is operating?
Try the following:
Ensure that the emergency brake (handbrake) is firmly applied and that the transmission is either in neutral (manual) or park (automatic)
Begin with a cold engine, remove the radiator cap and then start the engine.
Observe the coolant in the neck of the radiator
As the engine warms up, at the pre-determined temperature the thermostat will open allowing coolant to be pumped through the engine..
If you observe the coolant in the neck of the radiator, you will notice that the coolant will change from being still to beginning to "swirl" or "flow" indicating that the thermostat has opened and that the coolant is being pumped through the engine.
As soon as you see this, turn off the engine as the coolant will expand as it gets hotter and will flow out of the neck of the radiator.
If you don’t see this happening either the thermostat is faulty or perhaps the coolant pump may be faulty.
Be careful when you do this as the engine is running
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
faiz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,588
