跳转到主内容
The first generation of the executive car by Volvo known as the S80.
9 个问题 查看全部
How do I install a new window regulator on a 2006 s80/ drivers door.?
instructions to install a power window regulator
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The first step is to unhook your negative battery cable. Using painter’s tape, tape the window glass to the door frame to hold it in place. Next you will need to remove the inner door panel to access the regulator. Unfortunately Volvo rivets their regulators into place making them a pain to replace. You’ll have to drill out the rivets and either replace them with new rivets or I recommend replacing them with nuts and bolts. I found this guide online which includes a diagram of the rivets. I hope this helps, good luck with your repair!
https://www.matthewsvolvosite.com/forums...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jsweden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 346
