跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
197 个问题 查看全部
Does the LCD flex cable require micro soldering if it's damaged?
It is my first time attempting to replace the screen on an Apple watch altogether, and I tore off the LCD Flex cable, unfortunately, from what I am reading, I think it requires micro soldering…..does anyone know if this is correct? I sure hope not :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Yes this piece does require micro-soldering to replace.
这个答案有帮助吗?
得分 1
1条评论:
Thanks so much! Unfortunately for me, that means I have to find a micro soldering tech to do the work for me :( Oh well, either that, or I just buy a new watch, they only run about 150 now anyhow, that’s probably what I will do, and use this one to mess around with and learn with, I appreciate your response!! I honestly never realized people actually answered you on these forums, I will definitely be using this much more often!!
完成的
添加一条评论
@iphonefanatik - Hold on here! If you’ve damaged one or more of the three cables that go from the SIP to the display assembly as seen here
You’ll need a new SIP module as the cables are not available as a spare and you likely damaged the SIP logic board! As an example the iFixit team damaged their watch during the teardown! The two blue ovals are torn cabled one is lifted and the other fully ripped off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rachel Kelley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 569
